Product(s): | ProjectWise Explorer Client | ||
Version(s): | 08.11.11.590 | ||
Area: | MISC | ||
Original Author: | Dana Guthrie, Bentley Technical Support Group |
Error 58063: Invalid Username and Password Combination
User has created user accounts in ProjectWise using the User Synchronization service that brings in Windows Active Directory accounts into ProjectWise.
When his users attempt to log in they get the above error.
This error may appear regardless of whether you are using a ProjectWise logical account or a Windows account. The error is true to its word, something is not correct about the credentials that were entered.
Make sure you put the domain name in front of your user name.
Example: Bentley\Username
