| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.574 | ||
| Area: | MISC | ||
| Original Author: | Dana Guthrie, Bentley Technical Support Group |
How do I copy the view columns and a list of files to Excel Spreadsheet?
User is attempting to make a report using a view. Once the view was created the user did a search for the files they wanted in the report. At this pointed they wanted to copy the list of files along with the view column data to a spreadsheet.
Right mouse click on the files and choose ”Copy list to” , “Clipboard tab separated”
The view columns will become the headers of the columns in Excel.
Create a view that includes the folder properties you wish to capture, then change to that view.
Under your user settings \ Document List make sure you have the option to "Show Subfolders" turned on. I believe this is on by default. When you are in Projectwise and you click a parent folder and the subfolders appear on the right, then you have this setting turned on.
Highlight the Parent folder
Go to Document \ ”Copy list to” , “Clipboard tab separated”
Open an Excel Spreadsheet and paste the data into the spreadsheet.
Note this function will only copy the first level subfolders.
Enumfolders.exe is a new command line utility included with the V8i release of ProjectWise, and is a part of the ProjectWise Administrator install. The application is used to provide a way to report on ProjectWise folders/files. The program is also able to re-curse through the folder structure which allows a complete report of the hierarchal folder structure. This can be very useful for users who want to export the folder/file information from ProjectWise, to a text file for review. It can also be used for viewing the name of files and folders that have been deleted. (Note: this tool does not provide attribute data, only folder and file names)
For more information on Enumfolders see. EnumFolders Technote
