| Product(s): | ProjectWise Explorer Client V8i | |
| Version(s): | 10.00.01.67 | |
| Environment: | Windows 7 64 bit | |
| Area: | MISC | |
| Subarea: | N\A | |
Problem Description
Last Error 58030
Unable to create new document version.
Unable to create a directory for document version.
Getting Last error 58030, couldn't create folder when attempting to version a file.
The problem started when IP addresses were changed. The caching server was given a new IP address as well. The user has modified all DMSconfigs to the new IP address.
Steps to Resolve
Steps To Resolve
DNS issue. Had user report findings to their network group.
This issue was resolved when the old IP address was found in the Hosts file in the ProjectWise Integration server. Once they updated the Hosts file everything starting working as expected.
http://communities.bentley.com/products/projectwise/content_management/w/wiki/13671.error-58060-error-creating-a-new-folder-cannot-createdelete-folders-solution-500000090006
| | Original Author: | Raul Guerrero | |
