| Product(s): | MX Road | ||
| Version(s): | MX Road V8i | ||
| Area: | Project Settings | ||
| Subarea: | N/A | ||
| Original Author: | Purva Lakde. Product Advantage Group |
Problem Description:
Sometimes when we upgrade from MXRoad SS2 to MXRoad SS4, unable to open project file it throws error message as shown below.
Workaround:
Copy AU metric file i.e. AU_metric.+gui & AU_metric.+prm under C:\Program Files (x86)\Bentley\MX V8i (SELECTSeries 4)\MX\MFW\Parameters
Note: If you are unable to get those file then please refer the attached AU metric file for your references.
