| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.574 | ||
| Area: | Integration - Revit | ||
| Subarea: | Documentation / Help | ||
| Original Author: | Vickie Hewitt, Bentley Technical Support Group |
ProjectWise integrated Revit is an area of ProjectWise that is often perceived as not working correctly. This is mainly because it is integrated differently than most ProjectWise integrated applications and needs specific workflows.
As with many programs there are multiple workflows available in Revit and in ProjectWise. All of the workflows work but only specific workflows perform well in the integrated Revit environment.
Revit users working from ProjectWise are often using ProjectWise for the first time and are trying to work the way they always have and notice that performance is not good.
ProjectWise users and administrators are often using Revit for the first time and don't understand why things work the way they do.
Many users need to work with Revit files over slow connections. This Revit Integration file has been updated to describe options for working at high latency.
The document attached to this solution is the second in a series of documents explaining Revit Integration. This document is a detailed explaination of how Revit works, how ProjectWise Integration, how Integration works between ProjectWise and Revit and how to configure ProjectWise to allow Revit to work at high latency..
Before reading this document you may find it helpful to read the FAQ – Revit Integration document.
