| Version(s): | 08.11.07.428+, 08.11.09+ |
| Area: | Basic Settings |
Question:
Can multiple civil products be installed on the same machine?
Answer:
Yes, you can install multiple civil products on the same machine with the following exceptions and guidelines. These guidelines apply to civil versions 08.11.07.428 (SS2) and higher.
- You cannot install multiple version of the same SELECTseries on the same machine. For example, InRoads SS4 v.08.11.09.789 and InRoads SS4 v.08.11.09.845 cannot be installed on the same machine because they are both SELECTseries 4.
- If using layered products (i.e., GEOPAK running on top of MicroStation), you cannot install both SELECTseries 3 and SELECTseries 4 on the same machine.
- If using layered products, you can only have one version of MicroStation installed. You will need to install the MicroStation version that is compatible with the latest version of the civil product you wish to install.
- Access the softwares using their respective icons.
- Use separate MicroStation preferences (username & projectname) for each version.
- Datasets should be kept separate between the multiple versions.
