| Product(s): | InRoads |
| Version(s): | 08.09.03, 08.11.07+ |
| Area: | Geometry Design |
This video demonstrates how to use the Transform Geometry command to translate, rotate, and scale points and alignments. This command is useful when, for example, you have observations that were collected and processed using an assumed initial coordinate system. You can translate the resultant points and alignments to the appropriate coordinate system. You can also transform an entire geometry project from imperial units to metric units.
Click the video below to play it. To view in fullscreen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the fullscreen button (rightmost button at bottom of video).
