The following resources are provided as a reference by Bentley's Technical Support Group. They encompass the Bentley InRoads products.
- Video: Add Horizontal Alignment Point to COGO Buffer
- Video: Angle-Distance Constraint
- Video: Annotate Horizontal Alignment with Bearing and Distance
- Video: Annotate Vertical Elements Symbology
- Video: Civil Geometry Begin Elements
- Video: Civil Geometry Create Elements
- Video: Civil Geometry Feature Definitions
- Video: Civil Geometry Settings
- Video: Civil Geometry Simple Edits
- Video: Civil Geometry Simple Edits2
- Video: Create Compound Curve
- Video: Create Shunt Limits
- Video: Creating Horizontal Alignments Using Floating and Fixed Elements
- Video: Fit Compound Curve
- Video: InRoads 8.9 Annotating Stationing
- Video: InRoads 8.9 Creating Cul-de-sacs
- Video: InRoads 8.9 Creating a Simple ROW
- Video: InRoads 8.9 Entering Traverse Data
- Video: InRoads 8.9 Resolving Geometric Integrity
- Video: InRoads 8.9 Sight Distance Enhancements
- Video: InRoads 8.9 Tabling Geometry Annotation
- Video: Reverse Curve With Spiral
- Video: Solving For Unknown Geometry
- Video: Using Curve Fitting to Construct a Best Fit Alignment
- Video: Adjust Display of Stationing
- Video: Transform Geometry
- [[Creating a Centerline Alignment Between Two Horizontal Alignments]]
- Export Geometry Project (*.alg) to ICS (*.ics)
- [[Working With Cogo In InRoads 8.4]]
