| Product(s): | InRoads |
| Version(s): | 08.11.09+ |
| Area: | Text Import Wizard |
| Original Author: | Chris Key, Bentley Technical Support Group |
When importing a file through the Text Import Wizard, the preview doesn't show the correct formatting and there is odd text appearing. Cannot select multiple columns to bring in the information to a surface.
This is occurring because the file format is not recognized. In this situation, the file selected to import through the Text Import Wizard was a Microsoft Excel .xlsx format. The text import wizard cannot read this specific format so the file must be exported from Excel as a Comma Separated Value (.CSV) or Text file (.TXT) file so the import wizard can read in the ASCII information.
