| Product(s): | ProjectWise Design Integration V8i | ||
| Version(s): | 10.00.01.67 | ||
| Area: | Integration / Caching /Gateway | ||
| Subarea: | Installation |
After configuring dmskrnl.cfg PW Integration or Gateway server to run in secure mode (SecureConnection=1) the service will not start, with the following in the dmskrnl.log
Error 32768 "ssl_certFindCertificateInStore fails"
Error -91001 "requested certficate 'cert name' could not be found in the local store"
Fatal initialization error -11509 "ProjectWise Service: failed to start service in secure mode"
TLS 1.0 was disabled on the server
http://communities.bentley.com/products/projectwise/content_management/w/wiki/13472.which-secure-communication-protocol-does-projectwise-use-for-authentication
https://technet.microsoft.com/en-us/library/dn786418(v=ws.11).aspx#BKMK_SchannelTR_TLS10
| Original Author: | Molly Watts |
