| Product(s): | InRoads | ||
| Area: | Modeler | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
Is it possible to copy templates from one Template Library to another?
Templates can be copied from one Template Library to another using the Template Library
Organizer located within Tools on the Create Template menu bar.
