| Product(s): | Bentley MXROAD | ||
| Version(s): | MXRoad SS2 | ||
| Area: | MX with AutoCAD | ||
| Subarea: | N/A | ||
| Original Author: | Purva Lakde. Product Advantage Group |
Problem Description:
Launch MXRoad with AutoCAD it throws an error message of "The Ribbon does not have any tabs or panel currently loaded"
1. Enter the CUILOAD command when launch MX with AutoCAD.
2. Click the Browse button > Select ACAD.CUIX file and then click Load.
3. If it's already loaded, Unload it first and then load it again.
To save Settings, Enter command WSSETTINGS > Select Automatically Save Workspace Changes to save your settings.
