For ProjectWise Explorer CONNECT Edition Update 2 (10.00.02.96), the latest Office, ACAD, and Revit integration modules are bundled into the installer as in previous versions. If you have a supported version of Office, AutoCAD, or Revit installed, the ProjectWise Explorer installer will detect it in the registry as usual and offer the option to install the integration module related to that version of the application.
After installation, you may notice that the ProjectWise integration module you installed does not appear as a separate entry in the Control Panel > Programs and Features window. Instead, there is only an entry for ProjectWise Explorer CONNECT Edition.
If you need to install (turn on) or uninstall (turn off) any option of the installer that was not selected when you originally installed ProjectWise Explorer, of if you need to integrate with an application that was installed after ProjectWise Explorer was installed, you must uninstall ProjectWise Explorer and then reinstall it and select the options you want.
To uninstall:
or
Note: In the Programs and Features window, you may notice that when you right-click the entry for ProjectWise Explorer CONNECT Edition, there are two options: Change and Uninstall. The Change option does not work at this time and should not be used.
