| Product(s): | GEOPAK Drainage | ||
| Version(s): | N/A | ||
| Area: | Drainage Cross Sections | ||
| Subarea: | Create Drainage Structure Cross Sections | ||
This is a short video outlineing the basic setup for creating drainage structure cross sections in GEOPAK. You will already need your own criteria files created for each structure type that you want to display in cross sections.
Recorded in 1024 x 768 resolution.
