| Product(s): | ProjectWise V8i | ||
| Version(s): | 08.11.05.16 | ||
| Area: | Installation | ||
How can I manually install the viper viewer for V8i on a client machine?
On the publishing server got to C:\Program Files\Bentley\ProjectWise\Web\resources\Installs
Copy all the files from this directory to a folder on the client
Run RegisterDLLs.bat (double click the file - this copies the files to the proper location and registers the dlls)
Launch IE, and log in to WEL, the first time you publish a file you have to accept the EULA, but the VPR control should already be installed.
