| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.574 | ||
| Area: | Document Creation | ||
| Original Author: | Darius Perminas, Bentley Technical Support Group |
Last Error [55021]. Error creating new document. Not enough disk space available
The error pops up when trying to import a file from outside ProjectWise and there is no available disk space to create a file in storage. Storage has a dedicated location and it is out of space.
Monitoring of server resources ensuring that there is always enough of disk space. Otherwise, if the problem already occured, expand the storage by adding another disk, etc.
