| Version(s): | 08.11.09+ |
| Area: | Subsurface Utility Engineering |
Click the video below to play it. To view in fullscreen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the fullscreen button (rightmost button at bottom of video).
Note: editing a CFG file to load the DGN Library is shown, 13 minutes into the video. This file is used by Subsurface Utilities Engineering in the SELECTseries 3 versions of the Civil products. This file is not used at SELECTseries 4. For SELECTseries 4, you could edit a workspace .PCF file instead. For Power InRoads for example, these files can by default be found at: C:\ProgramData\Bentley\PowerInRoads V8i (SELECTseries 4)\WorkSpace\Projects\Examples
