Re-associate Horizontal and Vertical Alignment in an Existing OpenRoads Corridor
Version(s):08.11.09+
Area: Corridor Modeling
Original Author:Sanders Thomas, Bentley Technical Support Group
Question:
Is there an option to change or re-associate horizontal and vertical alignment in an existing OpenRoads corridor?
Answer:
There is now an option in OpenRoads 08.11.09.872 that will allow users to change or re-associate horizontal and vertical alignments. At the MicroStation Key-in, key-in “Corridor Reattach” and follow the prompts:
• Locate Corridor
• Locate Corridor Baseline (your new alignment)
• Locate Profile Element You will then see your corridor modified in your plan view.
https://youtu.be/lBOiRfffamE
