| Version(s): | 08.11.09.845+ |
| Area: | Subsurface Utilities |
This video demonstrates how to create UK storm data for peak flow and simulations, in Subsurface Utilities.
Click the video below to play it. To view in fullscreen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the fullscreen button (rightmost button at bottom of video).
Note: If you do not have the "UK Storm Profiles" Engineering Library that's used in this video, it can be downloaded here: UK Storm Profiles. Copy the .xml file to C:\ProgramData\Bentley\SUDA\8\Libraries.
This file needs to be registered. To do this, start your Civil product, then go to Subsurface Utility > Components > Engineering Libraries. Right click on Dimensionless Rainfall Curves, then click Add Existing Library, and browse to and select the UK Storm Profiles.xml file.
