| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.559 | ||
| Area: | Installation | ||
| Original Author: | Molly Watts, Bentley Technical Support Group |
After adding an additional server to PW network configuration, the previous datasources do not show
There is a duplicate datasource name on the new server. For example, server1:ProjectWise.Companya.com , server2:ProjectWise.Companyb.com Only one server will populate because of the duplicate name (regardless of domain name)
on the server named ProjectWise.companyA.com enter the following, which tells the client to send the traffic directly to that server.
ProjectWise.companyA.com=ProjectWise.companyA.com
OR
