Error 58510. Your ProjectWise user profile requires that you activate this ProjectWise product using the SELECT Server settings configured on this workstation.
However, a valid SELECT Server configuration could not be found, or the SELECT Server license is expired for this product.
This client will be denied access to the datasource. You may need to correct the SELECT Server configuration on this workstation.
There is a setting in ProjectWise administrator that tells the client how to get its license and this ProjectWise user was configured to use their local SELECTServer, but one was not configured.
Log into ProjectWise Administrator
Under users, go to the user account who is having the problem, right click properties, settings tab
**For this option You may need to check your SELECTServer license to make sure you have a ProjectWise passport license.
See also
License Management Tool
Activating Against SELECTserver OnLine
