| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.111 | ||
| Area: | Document Creation | ||
| Original Author: | Dana Guthrie, Bentley Technical Support Group |
What happened to my document and search wizards?
When I drag and drop a file into ProjectWise I used to get the option to use “No Wizard” or the “Advanced Wizard”. This dialog no longer displays
When I click on the search icon I used to get the option to choose the "Search Form" or "Search Builder". This dialog no longer displays
The reason the Document Creation Select a Wizard Dialog and the Select Search Definition Dialog does not appear, is that at some point you may have checked the option to “Make this wizard the Default’.
These two wizards are controlled by the Wizard Manager
In ProjectWise Explorer, go to Tools, Wizard Manager.
For document creation, Select the ‘Document Creation’ tab then click the “Clear Default” button.
For Searching, Select the ‘Search Definition’ tab then click the “Clear Default” button.
Clearing the default will bring back the dialog that allows you to choose your wizard when either doing a Search or Creating a Document.
