| Product(s): | InRoads | ||
| Version(s): | 08.09.03.06+ | ||
| Area: | Reports | ||
| Subarea: | |||
| Original Author: | Chris Key, Bentley Technical Support Group | ||
This report is the Clearance.xsl with the point description replacing the radial direction column.
Unzip the file communities.bentley.com/.../ClearanceDESC.zip and place it in the XML Data directory for the version of the product installed. This report may be placed in the Custom folder or the Clearance folder.
(ex for XM - C:\Program Files\Bentley\InRoads Group V8.9\XML Data\Custom)
(ex for V8i SS2 - C:\Program Files (x86)\Bentley\InRoads Group V8.11\XML Data\en\Custom)
(ex for V8i SS4 - C:\ProgramData\Bentley\Civil\ReportBrowser\8.11.9\en\Clearance)
