Bentley Transmittal Connector for ProjectWise
Here you will find more Information about
Bentley Transmittal Connector for ProjectWise:
MISC:
A Connection to Bentley Transmittal Server Could Not be Established
BTS Error, Sequence Contains No Elements in ProjectWise Explorer
Error Deploying Transittas "Another Device Already Exists with the Same Name"
To find more about ProjectWise check out the Table of Contents
