Difference between Geometry string and Master String
Product(s):MXRoad
Version(s):08.11.07.xx, 08.11.09.xx
Area: Strings
Original Author:Amita Shinde
Question :
What is the difference between Geometry string (GC string) and Master String (MC string)?
Answer:
Master Strings : are 6D strings and are generated from an alignment. Each point on Master string has 6 dimensions : x, y, z, chainage, tangent bearing and radius of curve. Each Master string has an associated Geometry string.
Geometry String : has 12 dimensions and store information about an alignment, for example, the horizontal and the vertical tangent points of the strings. A geometry string contains all the information necessary to generate the master string.
