| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.574 | ||
| Area: | Integration - MicroStation | ||
| Subarea: | Open / Close / Save As | ||
| Original Author: | Molly Watts, Bentley Technical Support Group |
Opening a DGN file from ProjectWise by double clicking on the document, MicroStation should open the file directly, however user is getting the ProjectWise login dialog within MicroStation before being able to continue
2. Finish the wizard and run it one more time, and install the Bentley MicroStation integration by selecting "This feature will be installed on local hard drive"
