| Product(s): | MicroStation V8i | ||
| Version(s): | 08.11.05.16 | ||
| Area: | AutoCAD | ||
User cannot open converted AutoCAD files in ProjectWise, but can open them outside of ProjectWise. Getting error "Cannot locate a default shx font. Please Install msdefault.shx. Program must now exit".
MicroStation V8i added a new folder and variable that points to the folder. Workspace\system\fonts\ was added to MicroStation V8i. This folder contains the default fonts to be used when a font used in the drawing can not be found. The variable MS_FONTPATH should be pointing to this directory.
You need to check the variable to verify that it is set correctly and then check the folder to verify that is does exist and the default fonts exist in the folder.
Error - cannot locate a default shx font
