| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.559 | ||
| Area: | Integration - MicroStation | ||
| Original Author: | Molly Watts, Bentley Technical Support Group |
After opening a pdf from ProjectWise, and sometimes get the Adobe error
"There was an error opening this document. This file cannot be found."
Then opening a dgn or dwg into MicroStation, MicroStation actually
opens the pdf file
Product: ProjectWise Client V8i
Version: 08.11.11.559
Area: Idesktop Integration, Problem ID#: 91701, PROBLEMSOLVING
The program association for the Adobe files had "enable legacy
integration" option turned on, unchecking that resolved the issue.
