| Product(s): | InRoads | ||
| Version(s): | 08.11.07.536 | ||
| Area: | Roadway Designer | ||
| Subarea: | |||
| Original Author: | Sanders Thomas, Bentley Technical Support Group | ||
When mapping point within the Edit Transition command, I use the Window Area command to close in on my point. However, when I select the Window Area command, I lose my dynamic link from my original point.
After selecting your point to map, use the scroll wheel on your mouse to zoom in and out, this will allow you to zoom in to your desired point.
