| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.559 | ||
| Area: | Integration - MicroStation | ||
| Subarea: | Install / Uninstall / Upgrade | ||
| Original Author: | Molly Watts, Bentley Technical Support Group |
C:\windows\system32\butil.dll is either not designed to run Windows or it contains an error
The butil.dll is an older dll that is no longer used on Windows 7
Delete (or rename) butil.dll from C:\windows\sysWOW64\ (or c:\windows\system32 on 32 bit machines)
