Video: Create a Reverse Spiral
Product(s):InRoads
Version(s):08.11.07+, 08.11.09+
Area: Geometry
This video demonstrates how to create a reverse spiral for a solution in existing geometry between circular arcs using the Define Spiral command.   This command is also used to define spirals between arcs and tangents, but this video will focus on a reverse spiral solution.
https://youtu.be/Q-Dz-5MjPyA
