| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.559 | ||
| Area: | Integration - MicroStation | ||
| Subarea: | Open / Close / Save As | ||
| Original Author: | Molly Watts, Bentley Technical Support Group |
The procedure entry point GetAttributeName...could not be located in the dynamic link library idattm.dll
Followed by this error in MicroStation:
"Error initializing ODMA"
There are two different versions of ProjectWise installed (PW XM and PW v8i) and the version currently opened is not the "active" version of ProjectWise
1. Run the Versionswitch command to change the active version
...\ProjectWise\bin\versionSwitch.vbs /811
...\ProjectWise\bin\versionSwitch.vbs /89
