| Product(s): | ProjectWise Explorer | ||
| Version(s): | V8i | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
Enumfolders.exe is a new command line utility included with the V8i release of ProjectWise, and is a part of the ProjectWise Administrator install. The application is used to provide a way to report on ProjectWise folders/files. The program is also able to re-curse through the folder structure which allows a complete report of the hierarchal folder structure. This can be very useful for users who want to export the folder/file information from ProjectWise, to a text file for review. It can also be used for viewing the name of files and folders that have been deleted.
To run the utility, open a command window from a system that has the ProjectWise Explorer client installed, and navigate to the ProjectWise/bin folder.
“C:\Program Files\Bentley\ProjectWise\bin\enumfolders.exe”
Running the command enumfolders.exe without any parameters will display the help.
Usage: enumfolders [-d datasource] [-u username] [-p password] [-v] [-r] [-D] [-l] [-f folder]
Enumerates the object in a folder hierarchy.
Options:
-d datasource hostname:datasource
-u user ProjectWise username
-p password ProjectWise password
-f folder ID Folder to the enumerate <GUID or integer folder ID>
-v Verbose operation
-D Include documents in object list
-l Include deleted object in object list
-r Recursive enumeration operation. All subfolders are
enumerated, along with any objects in those subfolders.
Sample keyin: this will enumerate all the files and sub folders from dmsfolder ID 140 in a datasource called MyDataSource
Enumfolders.exe –d SERVER: MyDataSource –u pwadmin –p prjwise –D –r –f 140
SERVER ProjectWise Integration Server
MyDataSource ProjectWise Datasource
-u pwadmin ProjectWise administrator username
-p prjwise ProjectWise administrator password
-D Used to include documents in the folder
-r Recurse through the folders
-f 153 Folder ID
Sample output: The output is in 6 columns
F 140 {6edc92bd-4568-4daf-9193-7e2d11b7ca28} "dms00140" "Folder" ""
F ? {d105d8d6-5ffa-4a70-a632-8826c0934f30} "UNKNOWN " "Folder\sub" "" (DELETED)
D ? {1a0a4f10-af2e-43f5-be0e-83d55e4fe24f} "UNKNOWN " "folder\sub\test.txt" "dmskrnl.cfg" (DELETED)
D 2 {053afb68-1090-432f-97fd-522280465ad9} "dms00140" "folder\stuff.txt" "stuff.txt"
The ‘UNKOWN’ under the dmsfolder number indicates that the folder ‘sub’ and the file test.txt have been deleted.
To output the data to a text file use the “>” sign.
Example:
enumfolders.exe –d SERVER: MyDataSource –u pwadmin –p prjwise –D –r –f 140 > c:\PWoutput.txt
This will create a text file called ‘PWoutput.txt’ with the requested data.
Example: enumfolders.exe -d MyDataSource -D -r -f 140
ProjectWise TechNotes And FAQs
Bentley's Technical Support Group requests that you please submit any comments you have on this Wiki article in the "Comments" area below. THANK YOU!
