ProjectWise's API can be accessed via VBA, allowing you to extend applications beyond the desktop. If you need to work with data that is stored in ProjectWise in your corporate environment, you can automate many tasks just by using VBA and the ProjectWise API. To use the API, you need to declare the functions that you plan to use. By encapsulating these calls, you can reuse them in many applications. In this article, we will use the simple process of logging in, checking out, allowing processing, and checking in of multiple documents in a ProjectWise document store. We need to declare the functions that will be used, then organize the application into reusable parts, and finally test the application.
First, set up the calls that need to be exposed to VBA from the ProjectWise API. The aaAPI class module is used to expose the C-based functions of the ProjectWise API to VBA. They are kept in one module to allow them to be reused in the application. There is also a Utility module to expose other functions that are necessary for both this and future projects.
The next phase is to build a set of classes that encapsulate the parts of ProjectWise that we will be working with. First is the datasource, which is in the clsPWDataSource class. This will be the point of the login and contain a reference to the collection of Projects that make up a datasource. Next, define the clsPWProject, which represents the Project information and contains a collection of documents. Next, define the clsPWDocument, which is the document class. Finally, there is the clsPWAttribute, which contains the document attributes.
The datasource class has the following properties and methods:
| class_initialize |
This method is called when a new reference to a datasource is created and contains the aaApi_initialize function call, which enables the rest of the aaApi calls to work. |
| login |
This method calls the aaApi_login function to connect to the datasource. |
| loginDlg | This method calls the aaApi_loginDlg function, which presents a user interface to login to the datasource. |
' Copyright: (c) 2006 Bentley Systems, Incorporated. All rights reserved.
' Module: clsPWDataSource.cls
' Status:
' Date:
' Author:
' Version: 1.0
' This class is a Connection to ProjectWise Datasource
Option Explicit
' Private Members
' User Information
Private strUserName As String
Private strPassword As String
Private strDataSource As String
Private blIsLoggedIn As Boolean
Private blIsMCMLoaded As Boolean
'Document Information
Private lngDocID As Long
Private lngProjectID As Long
Private strDocumentName As String
Private lngSetID As Long
Private lngAttibuteCount As Long
Private strAttributes(0, 0) As String
Private strGUID As String
' Public Members
Public Documents As Collection
Public Projects As Collection
' Public Properties
'User Name
Public Property Get UserName() As String
UserName = StrConv(strUserName, vbFromUnicode)
End Property
Public Property Let UserName(ByVal strNewUserName As String)
strUserName = StrConv(strNewUserName, vbUnicode)
End Property
'Password
Public Property Let UserPassword(ByVal strNewPassword As String)
strPassword = StrConv(strNewPassword, vbUnicode)
End Property
'Datasource
Public Property Get datasource() As String
datasource = StrConv(strDataSource, vbFromUnicode)
End Property
Public Property Let datasource(ByVal strNewDataSource As String)
strDataSource = StrConv(strNewDataSource, vbUnicode)
End Property
'System
Public Property Get IsMCMLoaded() As Boolean
IsMCMLoaded = blIsMCMLoaded
End Property
' Login Properties and Methods
Public Property Get IsloggedIn() As Boolean
IsloggedIn = blIsLoggedIn
End Property
' @description Logs a user into ProjectWise
' @param lngDataSourceType IN Datasource type to log into
' @param strLoginDataSourceName IN Datasource to log into
' @param strLoginUserName IN User name
' @param strLoginPassword IN User password
' @return
' @version 1.0
' @dependencies
' @example
' @remarks
' @alinkjoin
' @group
Public Sub Login(lngDataSourceType As DataSourceTypes, strLoginDataSourceName As String, strLoginUserName As String, strLoginPassword As String)
Dim lOK As Long
UserName = strLoginUserName
UserPassword = strLoginPassword
datasource = strLoginDataSourceName
lOK = aaApi_Login(lngDataSourceType, StrConv(strLoginDataSourceName, vbUnicode), StrConv(strLoginUserName, vbUnicode), StrConv(strLoginPassword, vbUnicode), "")
If lOK <> 1 Then
blIsLoggedIn = False
Else
blIsLoggedIn = True
BuildDataSourceInfo
End If
End Sub
' @return
' @version 1.0
' @dependencies
' @example
' @remarks
' @alinkjoin
' @group
Public Sub LoginDlg(lngDataSourceType As DataSourceTypes, strLoginDataSourceName As String, strLoginUserName As String, strLoginPassword As String)
Dim lOK As Long
lOK = aaApi_LoginDlg(lngDataSourceType, "", Len(strLoginDataSourceName), "", "", "")
If lOK <> 1 Then
Else
blIsLoggedIn = True
BuildDataSourceInfo
End If
End Sub
' Project Properties and Methods
Sub NavigateHierarchy(lngPID As Long)
Dim projectDatabuffer As Long
Dim numDocuments As Long
Dim iCount As Long
Dim oProject As clsPWProject
projectDatabuffer = aaApi_SelectProjectDataBuffer(lngPID)
numDocuments = aaApi_SelectDocumentsByProjectId(lngPID)
'Process top level only.
For iCount = 0 To numDocuments - 1
Set oProject = New clsPWProject
oProject.ProjectID = aaApi_DmsDataBufferGetNumericProperty(projectDatabuffer, PROJ_PROP_ID, iCount)
oProject.ProjectName = VBStringFromPtrW(aaApi_DmsDataBufferGetStringProperty(projectDatabuffer, PROJ_PROP_NAME, iCount))
oProject.Description = VBStringFromPtrW(aaApi_DmsDataBufferGetStringProperty(projectDatabuffer, PROJ_PROP_DESC, iCount))
oProject.BuildDocumentCollection
Projects.Add oProject
Next iCount
Dim subProjectDataBuffer As Long
Dim numChildren As Long
Dim iSubCount As Long
Dim childProjID As Long
subProjectDataBuffer = aaApi_SelectProjectDataBufferChilds(lngPID)
numChildren = aaApi_DmsDataBufferGetCount(subProjectDataBuffer)
For iSubCount = 0 To numChildren - 1
childProjID = aaApi_DmsDataBufferGetNumericProperty(subProjectDataBuffer, PROJ_PROP_ID, iSubCount)
Call NavigateHierarchy(childProjID)
Next iSubCount
aaApi_DmsDataBufferFree subProjectDataBuffer
aaApi_DmsDataBufferFree projectDatabuffer
End Sub
Sub BuildProjectCollection2()
Dim iTopLevelProjects As Long
Dim iCount As Long
Dim lngPID As Long
iTopLevelProjects = aaApi_SelectTopLevelProjects()
If iTopLevelProjects < 0 Then
MsgBox "error on projects collection" & GetLastErrorMessage & GetLastErrorDetail
Exit Sub
End If
For iCount = 0 To iTopLevelProjects
lngPID = aaApi_GetProjectId(iCount)
Call NavigateHierarchy(lngPID)
Next iCount
End Sub
Sub BuildProjectCollection()
projectDatabuffer = aaApi_DmsDataBufferSelect(AADMSBUFFER_PROJECT)
If projectDatabuffer = 0 Then
Exit Sub
End If
Dim numberOfProjects As Long
Dim iCount As Long
numberOfProjects = aaApi_DmsDataBufferGetCount(projectDatabuffer)
For iCount = 0 To numberOfProjects - 1
Next iCount
aaApi_DmsDataBufferFree (projectDatabuffer)
End Sub
Private Sub BuildDataSourceInfo()
Set Documents = New Collection
Set Projects = New Collection
End Sub
Private Sub Class_Initialize()
' See if MCM is loaded
If Utility.MDLIsLoaded("MCM") <> True Then
aaApi_Initialize AAMODULE_ALL
blIsMCMLoaded = False
Else
blIsMCMLoaded = True
blIsLoggedIn = True
End If
End Sub
Private Sub Class_Terminate()
'Logout
If datasource <> "" Then
aaApi_Logout datasource
End If
Call aaApi_Uninitialize
End Sub
The project class has the following properties and methods:
| BuildDocumentCollection |
This method iterates through the Documents in the project and creates a collection of clsPWDocuments. |
| CreateDocument |
This method allows a new document to be inserted into the project |
' Module: clsPWProject.cls
' Status:
' Date:
' Author:
' Version: 1.0
' This class is a Connection to ProjectWise DataSource
Option Explicit
Private lngDataSource As Long
Public lngProjectID As Long
Public strName As String
Public strDescription As String
Private Documents As Collection
Public Property Let ProjectID(id As Long)
lngProjectID = id
End Property
Public Property Get ProjectID() As Long
ProjectID = lngProjectID
End Property
Public Property Get ProjectName() As String
ProjectName = strName
End Property
Public Property Let ProjectName(strNameIn As String)
strName = strNameIn
End Property
Public Property Let DataSourceID(datasource As Long)
lngDataSource = datasource
End Property
Public Property Get DataSourceID() As Long
DataSourceID = lngDataSource
End Property
Public Property Let Description(strDesc As String)
strDescription = strDesc
End Property
Public Property Get Description() As String
Description = strDescription
End Property
Public Sub BuildDocumentCollection()
Dim oDocument As clsPWDocument
Dim numberOfDocuments As Long
Dim projectDocumentsBuffer As Long
Dim pAADocSelect As AADOCSELECT_ITEM
pAADocSelect.lProjectId = lngProjectID
'numberOfDocuments = aaApi_SelectDocumentsByProjectId(lngProjectID)
numberOfDocuments = aaApi_SelectDocuments(VarPtr(pAADocSelect), 0, 0)
If numberOfDocuments < 0 Then
MsgBox "error building doc list " & GetLastErrorMessage & GetLastErrorDetail
Exit Sub
End If
Dim iCount As Long
Dim id As Long
Dim lngDocType As Long
For iCount = 0 To numberOfDocuments - 1
id = aaApi_GetDocumentNumericProperty(DOC_PROP_ID, iCount)
If id <> 0 Then
Set oDocument = New clsPWDocument
oDocument.DocumentID = id
oDocument.ProjectID = lngProjectID
oDocument.name = VBStringFromPtrW(aaApi_GetDocumentStringProperty(DOC_PROP_NAME, iCount))
lngDocType = aaApi_GetDocumentNumericProperty(DOC_PROP_ITEMTYPE, iCount)
oDocument.DocType = lngDocType
Documents.Add oDocument
End If
Next iCount
'aaApi_DmsDataBufferFree projectDocumentsBuffer
End Sub
Property Get DocumentsCollection() As Collection
Set DocumentsCollection = Documents
End Property
End Sub
'' @description Create a document in the ProjectWise database
'' @param lngProjectID IN Project ID to create the document
'' @param strDocument IN Path and name of the document
'' @return True if the document was created successfully else False
'' @version 1.0
'' @dependencies
'' @example
'' @remarks
'' @alinkjoin
'' @group
Public Function CreateDocument(lngProjectID As Long, strDocument As String) As Long
Dim lngAppID As Long
Dim lngWorkSpceID As Long
Dim lngAttID As Long
Dim strFileName As String
Dim strFileExt As String
Dim strWorkingDir As String
Dim status As Long
lngAppID = 1
strWorkingDir = Space(MAX_STRINGLEN)
' Parse file
strFileName = fileNameParse(strDocument, FileNameOnlyType)
strFileExt = fileNameParse(strDocument, FileExtOnlyType)
strFileName = strFileName + "." + strFileExt
' Get IDs
lngWorkSpceID = aaApi_GetWorkspaceProfileId(lngProjectID, 0)
strFileExt = StrConv(strFileExt, vbUnicode)
lngAppID = aaApi_GetFExtensionApplication(strFileExt)
status = aaApi_CreateDocument(lngDocID, lngProjectID, 0, AADMS_FTYPE_UNKNOWN, AADMS_ITYPE, lngAppID, 0, _
lngWorkSpceID, StrConv(strDocument, vbUnicode), _
StrConv(strFileName, vbUnicode), _
vbNullChar, vbNullChar, False, _
AADMSDOCCREF_DEFAULT, strWorkingDir, MAX_STRINGLEN, lngAttID)
If status <> 0 Then
oDocument.Initialize lngProjectID, lngDocID
oDocument.DocType = aaApi_GetDocumentNumericProperty(DOC_PROP_ITEMTYPE, iCount)
End If
CreateDocument = lngDocID
End Function
The Documents collection holds the documents in this project. To add a document, the CreateDocument method is called on the project that holds the document.
The document class has the following properties and methods: CheckIn and CheckOut methods.
| CheckIn | Checks in the document that already exists in the project. |
| CheckOut | Checks out a document from a project. |
| CopyOut | Copies out the document to a local storage for working. |
| Initialize | Sets the document ID, project ID, and path for the document in the programmatic object. |
The document is checked in and out using the
'---------------------------------------------------------------------------------------+The main objects are supported by two helper modules that wrap functions for common and future use. First is the Utility module that contains some calls to get error reporting and process string data passed from VBA to MDL (or the ProjectWise API). Also included are calls to MDL functions that are used to work with MicroStation. The next module is the aaApi module, which contains definitions for all the ProjectWise API functions that are used in the Objects. This is done to allow the expansion of the ProjectWise API exposed without having to rebuild the Objects. These modules can also be referenced from other VBA projects, allowing for reuse of the code.
' Module: clsPWDocument.cls
' This class contains information about a document from ProjectWise
Option Explicit
' Private Members
Private blnIsCheckOut As Boolean
Private lngProjID As Long
Private strFullDocumentName As String
Private strCheckedOutName As String
Private lngDocItemType As Long
Private strPathToCheckedOutFile As String
' Public Property
Public Attributes As Collection
Public Property Get FullFileName() As String
FullFileName = strFullDocumentName
End Property
Public Property Let FullFileName(name As String)
FullFileName = name
End Property
'Datasource
Public Property Get DocumentID() As Long
DocumentID = lngDocID
End Property
Public Property Let DocumentID(id As Long)
lngDocID = id
End Property
ProjectID = lngProjID
End Property
lngProjID = id
End Property
Public Property Get name() As String
name = strDocumentName
End Property
Public Property Let name(strName As String)
strDocumentName = strName
End Property
Public Property Let DocType(DocType As Long)
lngDocItemType = DocType
End Property
Public Property Get DocType() As Long
DocType = lngDocItemType
End Property
Public Property Get CheckedOutName() As String
CheckedOutName = strCheckedOutName
End Property
Public Property Get IsCheckOut() As Boolean
IsCheckOut = blnIsCheckOut
End Property
Public Property Get AttributeCount() As Long
AttributeCount = lngAttibuteCount
End Property
' @description Checks in the document with the provided ProjectID and DocumentID
' @param lngProjectID IN Project ID of the document
' @param lngDocumentID IN Document ID
' @return True if the document was checked in successfully else False
' @version 1.0
' @dependencies
' @example
' @remarks
' @alinkjoin
' @group
Public Function CheckIn() As Long
CheckIn = 0
If IsCheckOut Then
CheckIn = aaApi_CheckInDocument(lngProjID, lngDocID)
End If
blnIsCheckOut = False
End Function
' @description Retrieves the documents attributes and add them to the collection
' @param
' @return
' @version 1.0
' @dependencies
' @example
' @remarks
' @alinkjoin
' @group
Private Function PopulateAttributes()
If aaApi_SelectEnvByProjectId(lngProjID) > 0 Then
Dim lngEnvID As Long
Dim lngTabNo As Long
Dim count As Long
Dim attributeDataBuffer As Long
lngEnvID = aaApi_GetEnvId(0)
lngTabNo = aaApi_GetEnvNumericProperty(ENV_PROP_TABLEID, 0)
attributeDataBuffer = aaApi_SelectLinkDataDataBuffer(lngTabNo, AADMSLDT_DOCUMENT, lngProjID, lngDocID, vbNullChar, 0, 0, 0)
If attributeDataBuffer <> 0 Then
Dim i As Long
count = aaApi_GetLinkDataDataBufferColumnCount(attributeDataBuffer)
lngAttibuteCount = count
For i = 0 To count - 1
Dim docAtt As clsAttribute
Set docAtt = New clsAttribute
docAtt.ColumName = VBStringFromPtrW(aaApi_DmsDataBufferGetStringProperty(attributeDataBuffer, LINKDATA_PROP_COLUMN_NAME, i))
docAtt.RowValue = VBStringFromPtrW(aaApi_GetLinkDataDataBufferColumnValue(attributeDataBuffer, 0, i))
Attributes.Add docAtt
Next
aaApi_DmsDataBufferFree attributeDataBuffer
End If
End If
End Function
' @description Checks out the document with the provided ProjectID and DocumentID
' @return Nothing
' @version 1.0
' @dependencies
' @example
' @remarks
' @alinkjoin
' @group
Public Function CheckOut() As Long
Dim status As Long
Dim strName As String
Dim strSize As Long
strWorkingDir = "d:\data\PWStuff\"
strSize = 512
CheckOut = aaApi_CheckOutDocument(lngProjID, lngDocID, StrPtr(strWorkingDir), strFullDocumentName, MAX_STRINGLEN)
If CheckOut = 1 Then
lngProjID = lngProjID
lngDocID = lngDocID
blnIsCheckOut = True
' status = aaApi_GetDocumentCheckedOutFileName(lngProjID, lngDocID, StrPtr(strName), strSize)
' If status = 0 Then
' 'strCheckedOutName = VBStringFromPtrW()
' End If
End If
End Function
' @description Initialize the document object.
' @param
' @return Returns 1 if the document was selected successfully.
' @version 1.0
' @dependencies
' @example
' @remarks
' @alinkjoin
' @group
Public Function Initialize(lngProjectID As Long, lngDocumentID As Long) As Long
lngProjID = lngProjectID
lngDocID = lngDocumentID
aaApi_SelectDocument lngProjectID, lngDocumentID
strDocumentName = VBStringFromPtrW(aaApi_GetDocumentStringProperty(DOC_PROP_FILENAME, 0))
aaApi_GetDocumentFileName lngProjectID, lngDocumentID, strFullDocumentName, MAX_STRINGLEN
PopulateAttributes
End Function
' @description Copy out the document with the provided ProjectID and DocumentID.
' @param
' @return Returns 1 if the document was copied out successfully.
' @version 1.0
' @dependencies
' @example
' @remarks
' @alinkjoin
' @group
Public Function CopyOut() As Long
CopyOut = aaApi_CopyOutDocument(lngProjID, lngProjID, "d:\data\pwstuff\", strDocumentName, MAX_STRINGLEN)
If CopyOut = 1 Then
PopulateAttributes
End If
End Function
strDocumentName = Space$(MAX_STRINGLEN)
strFullDocumentName = Space$(MAX_STRINGLEN)
Set Attributes = New Collection
End Sub
Set Attributes = Nothing
End Sub
To start, create an instance of the datasource object, which in its initialization initializes the ProjectWise API. Next, we need to be able to explore the datasource hierarchy, which is made up of Projects and Documents. The datasource allows us to build the collection of Projects, each of which having a collection of Documents. The Document object has the properties and methods necessary for working with the document in the ProjectWise context.
In the sample application, we build the objects and then process the datasource to find each design file, subsequently allowing the application to open each one and process the file. This application uses the non-interactive login, which means that we have to hardcode the login information directly into the application. First, the code creates the clsPWConnection object and after we have a connection, the application then can login. The project and document collections are created when the login is complete and finally, the sample application iterates through the collection of projects. Within each project, it iterates through the documents.
' Module: BDNzineExample
' Status:
' Date:
' Author:
' Version: 1.0
' This module demonstrates a simple connection to ProjectWise
Option Explicit
Sub BDNzineCheckOutAndProcessFiles()
Dim oPW As clsPWDataSource
Dim oDocItem As clsPWDocument
Dim lngProjectID As Long
Dim lngDocumentID As Long
Dim extString As String
Dim lStatus As Long
Dim oview As View
Dim oDesignFile As DesignFile
Dim pOriginalDGNFileName As String
'Save off the original file name to allow reopening the file at the end of the process.
pOriginalDGNFileName = ActiveDesignFile.FullName
' Create an instance of the clsPWDataSource class.
Set oPW = New clsPWDataSource
oPW.Login AAAPIDB_UNKNOWN, "computername:PWSample", "john.public", "a1b2c3d4"
Debug.Print "Datasource : " + oPW.datasource
Debug.Print "User Logged in : " + oPW.UserName
If oPW.IsloggedIn Then
oPW.BuildProjectCollection
If Not oPW.Projects Is Nothing Then
For Each oProject In oPW.Projects
Debug.Print "the project id is " & oProject.ProjectID & " the Project name is " & oProject.ProjectName
If Not oProject.DocumentsCollection Is Nothing Then
For Each oDocument In oProject.DocumentsCollection
Debug.Print "the document id is " & oDocument.DocumentID & " the file name is " & oDocument.name
extString = InStrRev(oDocument.name, ".dgn")
If extString > 0 Then
oDocument.CheckOut
Set oDesignFile = OpenDesignFile(StrConv(oDocument.FullFileName, vbFromUnicode), True)
For Each oview In oDesignFile.Views
If oview.IsOpen Then
oview.Fit True
End If
Next oview
oDesignFile.Close
oDocument.CheckIn
End If
Next oDocument
End If
Next oProject
End If
Else
MsgBox "Error on login " & GetLastErrorMessage & " " & GetLastErrorDetail
End If
'You don't need to logout since the destructor for the PWConnection class will do that for you.
Set oPW = Nothing
'This is done to leave us in a file, not in a blank MicroStation session.
If oPW Is Nothing Then
OpenDesignFile pOriginalDGNFileName, False
End If
End Sub
Lastly, the code above refers to a utility method VBStringFromPtrW that takes in the address of a WideChar Unicode string and returns an ANSI C MultiByte string: The code for the utility function is provided below. Make sure to place your constants and declare statements near the top of an appropriate "utility" source code module so it can be easily be shared among any VBA project needing such a conversion.
' Public constant definitions
Public Const CP_ACP = 0
Public Declare Function WideCharToMultiByte Lib "kernel32" (ByVal codepage As Long, ByVal dwFlags As Long, lpWideCharStr As Any, ByVal cchWideChar As Long, lpMultiByteStr As Any, ByVal cchMultiByte As Long, ByVal lpDefaultChar As String, ByVal lpUsedDefaultChar As Long) As Long
Public Declare Function lstrlenW Lib "kernel32" (lpString As Any) As Long
' @description Returns the string before first null char encountered (if any)
' from an ANSII string.
' @param
' @return Returns the string
' @version 1.0
' @dependencies VBIDE, IWshRuntimeLibrary
' @example
' @remarks
' @alinkjoin
' @group
' @bsimethod BSI-DEVSPT 06/04
' Returns the string before first null char encountered (if any) from an ANSII string.
Public Function GetStrFromBufferA(sz As String) As String
If InStr(sz, vbNullChar) Then
GetStrFromBufferA = Left$(sz, InStr(sz, vbNullChar) - 1)
Else
' If sz had no null char, the Left$ function
' above would return a zero length string ("").
GetStrFromBufferA = sz
End If
End Function
' @description Returns an ANSI string from a pointer to a Unicode string
' @param
' @return Returns an ANSI string from a pointer to a Unicode string
' @version 1.0
' @dependencies
' @example
' @remarks
' @alinkjoin
' @group
Public Function VBStringFromPtrW(lpszW As Long) As String
Dim sRtn As String
sRtn = String$(lstrlenW(ByVal lpszW) * 2, 0) ' 2 bytes/char
' WideCharToMultiByte also returns Unicode string length
Call WideCharToMultiByte(CP_ACP, 0, ByVal lpszW, -1, ByVal sRtn, Len(sRtn), 0, 0)
VBStringFromPtrW = GetStrFromBufferA(sRtn)
End Function
