| Product(s): | OpenRoads |
| Version(s): | 08.11.09+ |
| Area: | Vertical Geometry |
This video will demonstrate the options for adjusting a vertical profile using the 'Profile Adjustment' option. There are 3 values which can be set.
1. None - This option will not adjust any of the projection from the reference element.
2. Minimum - This will create the projected profile using the slopes or offsets from the reference element, but then will assign the elevation as a minimum elevation of the projection. Resulting in a set elevation profile based on the minimum elevation of the projection.
3. Maximum - This will create the projected profile using the slopes or offsets from the reference element, but then will assign the profile as a maximum elevation of the projection.
Click the video below to play it. To view in fullscreen mode, first click the YouTube link at the bottom of the video to launch the video on the YouTube site. Then, click the fullscreen button (rightmost button at bottom of video).
