| Product(s): | ProjectWise Client V8i | ||
| Version(s): | 08.11.07.443 | ||
| Area: | General | ||
Error 56013 cannot login to the datasource. Invalid database name
User was trying to connect an XM client to a V8i integration server. These two client server combinations are not compatible, upgrade client to same version as server.
