| Product(s): | ProjectWise | ||
| Version(s): | 08.05.0.152 | ||
| Area: | Explorer | ||
Error code - 32768 when trying to delete documents
I have been archiving data from our ProjectWise server. After exporting the data I am deleting the folders and documents from ProjectWise. I am receiving the following error code - 32768, description "error deleting document". I receive the same error when trying to check any document out. I have confirmed that the documents exist on the storage area of the server in the folder ID ProjectWise refers to.
The database log for the database in question was too large. We backed up the database and cleared the log. That took care of the problem.
