Product(s): | ProjectWise Explorer Client V8i | ||
Version(s): | 08.11.11.590 | ||
Environment: | Windows 7 64 bit | ||
Area: | Folders / Subfolders | ||
Subarea: | N\A |
The user was getting "Last error [ 58008 ] Error deleting a folder. Folder has subfolders. A folder that is a parent to other folders cannot be removed".
This user was not a member of the Administrator group.
Had user to ProjectWise Administrator - Users - user's account - Properties and then go to Settings - General and de-select the "Use access control". This allowed the user to see a subfolder containing documents underneath the folder he wanted to delete. After deleting the documents he could then delete the sub folder and the parent folder.
Original Author: | Van Kendall |
