| | Product(s): | ProjectWise Explorer Client | |
| | Version(s): | 08.11.11.559 | |
| | Area: | Export / Import Tool | |
| | Original Author: | Dana Guthrie, Bentley Technical Support Group | |
Where can I find the ProjectWise Export / Import tool (with excel) install set
The ProjectWise Export/Import tool is now delivered with the release of Projectwise Client setups version 08.11.11.559 and up.
Go to the Software Fulfillment Center, and under ‘Brand’ choose Projectwise.
Change the Language to your preferred Language, then scroll through the results till you find Projectwise Explorer Client.
Click the ‘All downloads’ button and then choose and download the version of ProjectWise you are currently running on the client.
If you have already have the client install sets downloaded, Simply run the setup.exe that comes with the client setups, and the ProjectWise Export / Import tool will be the last option on the list.
If you need an older version of the ProjectWise Export / Import tool you will need to download it as a separate install from the Software Fulfillment center.
Go to the Fulfillment Center.
Under ‘Brand’ choose SolutionsWare, find Bentley Projectwise Export/Import in the list and click on the ‘All Downloads’ link.
There you will find the older versions of this program.
Software Fullfilment Center
Right Click Document Folder Export, Tools Export Import Wizard, Export Import with Excel TN
