| Product(s): | ProjectWise Client | ||
| Version(s): | All | ||
| Area: | Import/Export to Excel | ||
During the Export to Excel Wizard there are different options available. Copy Out Documents Versions is on of these options. User is getting this option always greyed out.
The Copy out Document Versions can be toggled ON/OFF if you have the Mark Document As Exported enabled or disabled. If this option is still showing as greyed out. The settings of the user exporting it needs to be check.
User settings > Settings > Document List > Show all Versions > Enabled / Disabled
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this " Comments or Corrections?" section. THANK YOU!
