| Product(s): | ProjectWise V8i | ||
| Version(s): | 08.11.05.16 | ||
| Area: | Explorer | ||
Error 58040 Error copying document. When logging into ProjectWise client and this error occurs and a background map is being used, verify that the user has read privileges to where the background map is located.
A sample of the error message will read as follows:
Last Error [58040]
Error copying document '55:3' to client.
Access denied. You have insufficient privileges to finish this operation.
Where '55:3' actually represents the folder ID and document number of the users last opened file.
The user will have to have read privileges to where ever the background map is stored.
