Error 7209065 Creating a new folder - Access Denied
 Product(s):ProjectWise V8 XM Edition
 Version(s):08.09.04.63
 Area: Explorer
Problem Description
Trying to create a folder in ProjectWise gives error 7209065 "Error creating a new folder - access denied. You have insufficient privileges to finish this operation."
User had correct permissions.
Problem was with the database, it was set to autogrow, but had reached its maximum size. after increasing it, user was able to create folders again
Rrror in dmskrnl.log:
ODBC ERROR: 42000: [Microsoft][ODBC SQL Server Driver][SQL Server]Could not allocate space for object 'dbo.dms_proj'.'i_dms_proj_1' in database 'ProjectWise' because the 'PRIMARY' filegroup is full. Create disk space by deleting unneeded files, dropping objects in the filegroup, adding additional files to the filegroup, or setting autogrowth on for existing files in the filegroup."
Product TechNotes and FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" sectioXn. THANK YOU!
