| Version(s): | 08.11.09+ |
| Area: | General |
| Original Author: | Sanders Thomas, Bentley Technical Support Group |
Question:
User often have questions regarding how to determine which version of MicroStation is compatible with InRoads products.
Answer:
The best method to determine compatibility is to log onto the CONNECTION Center and select Software Downloads. When the desired version of InRoads selected, dependencies will always list the compatible version of MicroStation.
