Last Error - Error Deleting folder
 Product(s):ProjectWise Client V8i
 Version(s):08.11.05.16
 Area: General
Last error [-1} Error deleting folder - can't delete empty folders in ProjectWise
To fix the problem you will need to do the following:
Grab logs to find the storage area dmsfolder, then delete anything in there. There might be thumbs.db file.
Product TechNotes and FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
