| Version(s): | 08.05.02.55 | ||
| Area: | ProjectWise | ||
User is in a file and upon exit, user gets Raster Message Projectwise Message to be sure to check in his file. User does not have Projectwise
To disable the Raster Manager warning dialog box, create the following new variable in Microstation:
MS\Workspace\Configuration
Create a new variable?set the value to 1!
MS_RASTER_PROJECTWISE_WARNING_ONCLOSE_DISABLE:
< CR>Absent: No effect
0: No effect
1: Disable the warning dialog displayed when we close the DGN, if we are thinking the files are opened from PW.
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this " Comments or Corrections?" section. THANK YOU!
