| Product(s): | ProjectWise V8 XM Edition | ||
| Version(s): | 08.09.04.63 | ||
| Area: | Installation | ||
User is trying to integrate PW with MicroStation and InRoads, but is unable to do so. There is no error displayed, but when they try to save or open a file, they do not see the ProjectWise folder, they only see the windows folder.
added the path to the bin folder.
Troubleshooting:
Launching Microstation from the desktop does prompt you for PW login dialog, but launching a dgn from PW the integration does not work and he gets error finding mcm.ma
If he logs on to the system as himself it works, but logged on as the user does not.
try purging the working directory via doc organizer including workspace files? Then delete and recreate the users workdir?
User had a personal workspace setup. Had two variables in it. One was MS_MDL and cannot recall the other.
It was something to the effect of MS_CAPABILITY_LEVEL_ etc.
Removal of this and reinstallation of the client worked.
