| Product(s): | ProjectWise Client V8i | ||
| Version(s): | 08.11.07.107 | ||
| Area: | General | ||
No references processed when running scan for references (scanref)
The masters the user was trying to scan where read only to him.
Scan ref requires the ability to write to the header of the file, therefore the user needs the file write permission to all masters he is running scanref on.
