| Product(s): | ProjectWise Explorer Client | ||
| Version(s): | 08.11.11.574 | ||
| Area: | Project | ||
| Original Author: | Dana Guthrie, Bentley Technical Support Group |
Change storage area for a Project Template
In my templates folder, I have a project template that I would like to change the storage area on. I right mouse click on the project folder, choose properties and then change the storage area and hit okay. However the storage area change does not inherit down through the rest of the folders and files. How can I change the storage area for the entire folder structure without doing it manually one folder at a time?
The easiest way to do this would be to create a new project template using the old template and through the wizard change the storage area, checking the box that says “set for subfolders and subprojects”.
