In this video you will learn how to setup our custom ProjectWise Project Creation Automation tool. As you know, the setup of projects in ProjectWise have grown in complexity over time. Projects are now containers for multiple data types and structures, which include artifacts or links to other components. For example, Work Areas in ProjectWise Design Integration that can be linked to a connected project in ProjectWise365, or ProjectWise Deliverables Management instances that can be leveraged from a ProjectWise Design Integration project. The setup of these functions, until now, have been manual configurations. This tool will aid users in the automation of these configuration steps.
