Product(s): | ProjectWise Explorer Client V8i | ||
Version(s): | 08.11.11.605 | ||
Environment: | Windows 7 64 bit | ||
Area: | Integration - AutoCAD | ||
Subarea: | Enable / Disable integration |
User is getting the following error when opening AutoCad files from ProjectWise Explorer V8i SS4 version 08.11.11.605. The user has AutoCad 2014 loaded with the ProjectWise Integration Module for Autodesk AutoCAD 2104 version 08.11.11.749
Removing the ProjectWise Integration Module for Autodesk AutoCAD 2104 version 08.11.11.749 and loading the ProjectWise Integration Module for AutoCAD 2014 version 08.11.11.855 fixed the issue.
Original Author: | Van Kendall |
